Supercharged 5.3L. Thinking about adding a Wet Shot, Comments, Suggestions?
Old Jul 1, 2010 | 12:54 PM
Bullitz400's Avatar
Default Supercharged 5.3L. Thinking about adding a Wet Shot, Comments, Suggestions?
Here is my set-up.
2001 5.3L. Stock Internals. Procharger set at 11 lbs. 44 lb injectors, walbro fuel pump, Long Tubes, Side exhaust cat back 3", FLT LVL 7, Yank 3200. Truck made 370 / 370 at the wheels when dyno tuned.
Thinking of adding a 100 wet shot and spray before the maf. What are your suggestions. Thanks
Old Jul 1, 2010 | 02:05 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Fuel pump?
No Meth to help fuel?
Other than a possible lean condition due to lack of fuel I say why not?
Oh, wet sprays after the MAF, ok?
Old Jul 1, 2010 | 02:17 PM
03tahoe22's Avatar
11lbs and a 75hp wet shot after the maf just like trever1t ^^^^ used to run...... I want to drop to 8lbs to lower to iat and freeze it with a two stage 50hp launch and 75hp after the shift into second. Stock internals.
Old Jul 1, 2010 | 02:43 PM
Bullitz400's Avatar
No meth, Just the walbro 255 inline pump. I heard it would be safe from either a 50-100 as long as it was a wet shot. Any more advice would be appreciated. Just going to have a WOT switch for it to activate.
Old Jul 1, 2010 | 02:57 PM
grey matter 04's Avatar
13 Second Truck Club
anybody else think the numbers are low for 11#s?
Why not change the cam and pickup power? way safer than spray
I bet with a LS6 cam you will gain over 40 at the tires
Old Jul 1, 2010 | 03:26 PM
TX Tahoe Z71's Avatar
That was my first thought. I put down 367/407 at the rear on stock manifolds with 8psi on my MP112 with just a CAI and 22" magnaflow muffler on the stock piping.
Throw a cam in that since you already have the fuel pump and injectors to support it, you would have that on tap all the time and no bottle to refill.
EDIT: Just saw you are selling an LS6 cam, springs, and pushrods. Why not throw them in there since you already have it?
Old Jul 1, 2010 | 08:44 PM
blue0453's Avatar
yeah that power seems kinda of low for 11lbs. mine made 410/390 on 7lbs on 12.5 degrees of timing. and that was on a mail order tune
Old Jul 4, 2010 | 07:42 AM
Spoolin's Avatar
GFYS and STFU
Numbers do sound a bit low. I was just over 400/400 at the wheels at 8 psi. That was with a turbo however. In any case, start with a small shot and go bigger from there to see how it feels.
Old Jul 6, 2010 | 07:49 AM
stoffer's Avatar
I paid my buck-o-five
Originally Posted by Bullitz400
Here is my set-up.
2 or 3 core i/c???
Old Jul 8, 2010 | 03:02 PM
WJ MARK's Avatar
sell the procharger and buy a turbo kit from Trick like I did. I made 338 or so with my procharger at 8psi. switched to a turbo about 10 psi and made 438/515. added an ls6 cam and alittle meth and made 486/505.
Or just spray the **** out of it, LOL.
