super vic jr.
Old Aug 16, 2009 | 06:56 PM
05crew's Avatar
Default super vic jr.
what is the diff. in a super vic jr. and a vic jr intake. what will work better on a turbo 408?
Old Aug 16, 2009 | 08:36 PM
nightrunner's Avatar
Mr. Obvious
might double check but i believe that the super vic jr. doesnt have fuel injector bungs, but i may be wrong
Old Aug 16, 2009 | 08:48 PM
MikeGyver's Avatar
From Edelbrock's website:
"Super Victor EFI LS1 manifold #28095 is for high-output competition EFI systems and features precisely positioned and machined injector bosses for excellent fuel spray patterns and maximum power."
Old Aug 16, 2009 | 08:52 PM
Mr. Obvious
my bad, must be thinkin of something else
EDIT, i was thinking of the performer rpm
the only difference i can find between the vic jr. and the super vic is the super is about 1.1" taller
Old Aug 16, 2009 | 08:54 PM
BlackGMC's Avatar
Resident Retard
I believe it has to do with the hieght/length of the runners which has to do with the rpm range....
Old Aug 16, 2009 | 09:12 PM
05crew's Avatar
so it would be good for the turbo setup? i would think so because of the long runners
Old Aug 16, 2009 | 09:13 PM
Mangled03gmc's Avatar
Baltimore Whore
Be the test mule..
Old Aug 17, 2009 | 09:46 AM
Mort's Avatar
Will the super fit under the hood?
The shorter runners must be better for low end torque and therefore better on the street and the long runners better for top end and therefore better for an all out track truck. Depends on your goals. I have read the theory but I am not sure if I have it right or exactly what the effect of either will be on drive-ability or how it ties in with your turbo.
I would try to determine which will suit your build and goals and then you can make a more informed decision.
Maybe Richard at WCCH can help steer you in the right direction. I think he sells Edelbrock.
Nice build you are doing!
Old Aug 17, 2009 | 09:52 AM
BlackGMC's Avatar
Resident Retard
I believe you have it backwards... Short runners have a higher air intake velocity which hurts lowend but help upper rpm HP. Long runners have a lower air intake velocity which helps lowend TQ... At least that is what i remember reading....
Old Aug 17, 2009 | 10:22 AM
Mort's Avatar
LOL....you are probably correct. I read these things out of general interest and often seem to get it wrong from memory. Sorry if I mislead anyone.
