sudden boost drop higher rpms procharger
Old Aug 27, 2020 | 05:34 PM
bidgaf's Avatar
Well the bov is getting replaced regardless. I have a 50mm flange and I found a percision and tial unit to replace the cheap one. The tial reccomends a 2 psi for supercharger applications, but that doesn't sound right to me. Any input on which one and also what spring I should get for it?
Old Aug 27, 2020 | 06:00 PM
arthursc2's Avatar
The lighter the better so it bleeds off at idle and tightens up when it senses boost. Make sure you have a ref line feeding the top of the bov
Old Aug 27, 2020 | 06:22 PM
bidgaf's Avatar
Originally Posted by madmann26
Is your crank pinned?
No it is not, will pin and retest.
Originally Posted by BigKID
The bold statement caught my attention. Is there a noticeable power loss associated with the boost drop? Are you seeing an airmass change thru the MAF?
EDIT... I may have misread the statement. I read it as you are seeing the boost drop on teh log but not on the boost gauge however you may mean the log is the only reference you have?
I wouldn't say noticeable, still pulls strong. I'm going off the map sensor, no maf because I'm running speed density.
Old Aug 27, 2020 | 11:33 PM
arthursc2's Avatar
I bet it's the crank spinning in the pulley
Old Aug 28, 2020 | 11:12 PM
skolman91's Avatar
Bov or something on the inlet side of the charger sucking shut, a weak coupler or even filter..
Jake99
Mar 28, 2017 08:02 PM
YenkoST
Nov 18, 2014 08:38 PM
Three6GMC
Oct 26, 2012 06:19 PM
Rick_Vor
Sep 3, 2009 02:34 AM
peppersac
Oct 23, 2006 09:11 AM
