Stupid belt issue
Old Sep 30, 2020 | 03:19 PM
chevyboy.520's Avatar
Default Stupid belt issue
So my truck loves to throw bolt the serp and AC belt when I have the truck on the high boost setting.
my high boost is 24lbs
low boost is 15lbs
so I don’t really have the issue on low boost
but on high boost it will throw the belts
I have a brand new AC delco tensioner for both belts and brand new belts for both!
the SERP belt is actually the size for the 105 amp alt so it’s a tight fit
and it still gets thrown off
does any ones else have an issue with throwing belts with a turbo set up?
Old Oct 1, 2020 | 05:09 AM
madmann26's Avatar
Are your pulleys perfectly aligned? This and crank pinning is what causes it.
The AC belt you can convert to a 2008 belt that doesn’t use the tensioner.
Old Oct 1, 2020 | 06:22 AM
I have Oreilly auto parts getting me a stecth fit belt!
ill try that
and as far as alignment, everything is stock and should be good! But that doesn’t mean **** lol! I had a alignment tool on it and it seemed fine. But I still have the issue
Old Oct 1, 2020 | 06:56 AM
madmann26's Avatar
ill try that
Is your crank pinned? That WILL cause it also.
Old Oct 1, 2020 | 08:59 AM
Atomic's Avatar
I have a gauge for that
Put a gopro under the hood and watch it
Old Oct 2, 2020 | 02:00 PM
next time I’m out messing around I’ll throw the GP under the hood to watch what is happening
Old Oct 2, 2020 | 02:01 PM
crank is Not pinned! Didn’t think I would have to do that since it’s a turbo truck and not blower
Old Oct 4, 2020 | 12:09 PM
Forcefed81's Avatar
Not to highjack this thread, but can you explain how the crank pinning causes this? I only ask because I am having a similar issue. I have a 6.0L with a whipple, with a pinned crank, and I am having trouble with the belt. Every time I go WOT it tosses the belt. It starting to drive me mad. I have tried a couple different belts to no avail. I could really use a solution.
Old Oct 4, 2020 | 03:12 PM
terravast4's Avatar
You need to make sure your pullies are aligned properly
Old Oct 4, 2020 | 06:07 PM
xxch0dyxx's Avatar
I have this issue intermittent on my setup as well when going full tilt. All pulleys aligned. Crank is pinned.
Tried various belts, new tensioner, etc. Haven't found solution, so I took AC belt off this week because it's getting cooler out.
Another member said he had an extra groove machines closer to his main belt and it hasn't hopped since. I have IW OD crank pulley so not interested in that.
