sts to trick oil line
im geting a set of hot pipes to swap to a trick front mount. I know a lot of guys must have done this exact swap. Can I still run the sts oil lines w/out the pump if i shorten them or would i necessarily have to tap the pan?
about a 5ft -3 feed line for oil supply. Are you using the "sts" oil cap for the return? You will need to tap the oil pan above the oil level for the oil to velocity feed back into the pan from the front mounted turbo.
Yes you will need to tap the pan. Its easy to do you just need a 3/8 tap and drill. can be done on the vehicle. heres a pic we did on an 08..
We can supply you a 5' -3 line with the pipes.
GXPJAY
Feb 13, 2022 08:15 AM
GXPJAY
Jan 27, 2016 11:45 AM
ZO6Ted
Aug 12, 2015 07:50 PM
