STS Question for LS1 Swap into 97 Z71
Old Dec 24, 2008 | 06:31 PM
1BADAZZSS's Avatar
Turbo 6.0 is the the guy you need to be talking to as far as the sts to fit on your truck. If I remember right he works for sts.
Old Dec 24, 2008 | 07:24 PM
kbracing96's Avatar
Originally Posted by exodus
do you think that there will be any interference with this being in the 97 body? Motor will be a 98 LS1, but the 97 model Z71.
What size up and down pipes come with your t-76 kit?
I've never put a kit on a obs, might need to do a bit of work to make it all fit, idk.
The cross over and is 2 1/2" and the down pipe is 3". To upgrade to a MP t-76 is only $200. That's what I'm running on my own truck.
Old Dec 25, 2008 | 12:05 AM
exodus's Avatar
just so I am clear, the complete t-76 intercooled kit complete minus the fuel sys and tune would be $4400 plus shipping?
Old Dec 25, 2008 | 10:00 AM
kbracing96's Avatar
Yep, everything in this pic
Old Dec 25, 2008 | 10:53 AM
ducky's Avatar
Personally I think if your gonna be offroading and such, a front mount might be a little safer to run then a rear..
Old Dec 25, 2008 | 12:10 PM
exodus's Avatar
full skid plate in that area, so not quite as worried, besides the 6-8" lift for some clearance. Planned onmounting tight to the bed and covered with the plate in the area for some protection. Besides I haven't ruled out the front mount as it would keep the intake up high too.
Old Dec 25, 2008 | 12:11 PM
exodus's Avatar
on the KB kit, I'm assuming the driver's side manifold is retained?
Old Dec 25, 2008 | 12:15 PM
exodus's Avatar
Just to be sure, this is all of the hot and cold side piping in this pic?
Old Dec 25, 2008 | 01:42 PM
1BADAZZSS's Avatar
Well all depending on what he means offroading. You go through a mud hole and the front mount would get muddy just as the rear mount would too. As far as clearance. The rearend would bottom out before the turbo did on a rear mount.
exodus- how much was sts wanting for the universal kit and what all does it come with. Meaning-turbo,wastegate,bov,charge pipe,oil pump,feed and oil return lines, t flange,etc?
Old Dec 25, 2008 | 06:31 PM
kbracing96's Avatar
Yes the stock truck drivers side manifold is used with my kit.
Yes, everything in the pic (hot and cold piping) in post 3 is in the pic in post 14, plus the oil feed and drain lines and coolant extension hoses, WG and BOV and misc fitting and hard ware.
