STS Question
Old May 16, 2006 | 04:15 PM
TIM Z's Avatar
11 sec. Truck Mod
ask STSsilverado about meth, his ran out on high boost and blew his baby up, im just suggesting to be careful about keeping your meth full, most people use the washer fluid cuz it has a low warning light. just sum info mon -e -pit. meth is an awesome tool for FI applications, and an FMIC is worry free.
Old May 19, 2006 | 08:57 AM
MON-E-pIT's Avatar
Thanks. I just purchased the kit and intercooler. I will get the meth injction later. How much boost can I run on stock internals, and do I need new injectors right away?
Old May 19, 2006 | 09:06 AM
Charged_5.3's Avatar
On stock internals I think maybe around 8 psi. Of course you could run higher boost but eventually the motor gonna break unless you get forged internals. As for fuel injectors, you don't need them right away if you're staying at 5 psi. If you're planning on running more boost, then you'll to upgrade them.
Old May 19, 2006 | 09:38 AM
quicksilverado's Avatar
I would not go over 5 psi without injectors and fuel pump.
Old May 19, 2006 | 09:59 AM
MrXerox's Avatar
I have a set of 8.1 31lb truck injectors that I will let go for $150.00 shipped if you are interested. They should allow you to get to 10lbs easily over the stock 24lbs ones and they will drop right in....
Old May 19, 2006 | 11:16 AM
greentahoe's Avatar
people have gone 15+ on stock internals. Your tune needs to be dead nuts on though. You also need adequate fueling. I wouldnt go that high without 60lb injectors and meth.
Old May 19, 2006 | 04:47 PM
Probably, but the motor won't last as long though.
Old May 19, 2006 | 04:55 PM
TIM Z's Avatar
11 sec. Truck Mod
definitley upgrade the pump and injectors!!!!even on low boost, better safe than sorry, and get a Wideband gauge along with some type of gauge/scanner so to keep track of your timing and Knock retard.
Old May 19, 2006 | 05:30 PM
31s will not supply enough fuel for 10 psi. My old 33s were maxed out at 8 psi.
Old May 19, 2006 | 11:48 PM
MrXerox's Avatar
What do the duty cycles look like at the standard 6psi on the stock 24s then?
