Sts Owners
Old Jun 8, 2006 | 10:44 AM
Bolo7735's Avatar
Default Sts Owners
Hello Everyone, I'll be purchasing the STS within a few months. I want to know how many STS owners are running stock internals and at what safe psi?
What about the tranny and rear end? I have a 04 Denali XL 6.0L.
Richard
Old Jun 8, 2006 | 11:00 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Cant answer your question but can Welcome you to PT.net! Someone will be along shortly with STS experience!
Old Jun 8, 2006 | 11:32 AM
vanillagorilla's Avatar
10psi stock internals, no IC.....yet.
Old Jun 8, 2006 | 11:40 AM
Bolo7735's Avatar
Wow, thats pretty good. Im planning to get the FMIC and larger pump and injectors. If I can get my truck running low 13's all day Im happy.
Old Jun 8, 2006 | 01:31 PM
Whippled 496's Avatar
WOW! 10psi and no I/C? What kind of IAT's are you seeing?
LOL, i would like to get high 13's. Hopefully this I/C im finishing up with will help me get there.
Old Jun 8, 2006 | 01:33 PM
Injected1's Avatar
I will be running 11 soon as I get everything hooked up. I will find out the max safe PSI soon as I get my 408 built
Old Jun 8, 2006 | 01:36 PM
It's a Denali XL....like a Suburban? That's a big *** truck to get running 13's. I'm not saying its not possible, but that would be awesome to see. I know there are guys here that are running +12psi on stock internals or at the most rod bolts.
Go straight for an upgraded turbo though, not the standard one with the kit, and you'll obviously need a turbo friendly cam and a custom tune to get you there. You WILL need the injectors IC and fuel pump like you stated. A BOV will be needed at boost levels that high, and a boost controller wouldn't hurt. You'll need a torque converter too, to match the cam and to get the ET.
FlaBouy's Avatar
I have been running 12 psi on stock internals since September with a non-intercooled Vortech so would assume you should be able to do the same, although I am probably out on the edge of the stock internals....
Old Jun 8, 2006 | 01:38 PM
I just started seeing 150-160* IAT's @ WOT, but that's because it's been about 106-107* out. After a WOT run though, the IAT's won't drop, because everything is totally heat soaked. But before that.....
Old Jun 8, 2006 | 01:40 PM
FlaBouy's Avatar
It's a Denali XL....like a Suburban? That's a big *** truck to get running 13's. I'm not saying its not possible, but that would be awesome to see. I know there are guys here that are running +12psi on stock internals.
Hehe, I have a big *** truck running low XX's. 6000 lb shoebox. My buddy in Orlando is running about 75 hp less on his AV and ran a 13.6 @ 101. He was running a Radix @ 8 psi with no stall at the time.....
