STS oil return mod
Old Feb 9, 2006 | 05:33 PM
TchargedLS1TA's Avatar
Default STS oil return mod
Here are some pics and a parts list for what seems to be a decent way to tap the oil pan during an engine swap or if you can drop the pan..
The parts I got from Summit:
SUM-220010 -6AN Fast Flow Bulkhead Fitting $10.95
AER-FBM1532 -6AN to barb 90* Fitting $13.95
And its that cheap. The bulkhead fitting comes with the fitting, nut and 2 nylon washers so t seems to be a pretty leak proof design I guess.. I still dobbed some silicone under the washers for peace of mind..
This one is mounted about 4" ahead of the sump in the pan..
Attached Thumbnails STS oil return mod-oil-fitting2.jpg   STS oil return mod-oil-fitting.jpg
Old Feb 9, 2006 | 08:00 PM
TIM Z's Avatar
11 sec. Truck Mod
nice job, id like to just get some braided ss line and an alum oil cap tapped to return the oil, im skerrred to drill into my oil pan.
Old Feb 9, 2006 | 08:58 PM
vanillagorilla's Avatar
Nice work man! BTW, dropping the pan isn't too hard to do in these trucks, as the engine crossmember un-bolts with 4 botls. And the gasket is "re-usable" too.
RoidedSS
Aug 11, 2015 11:51 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Deceptarado
Jul 8, 2015 05:24 PM
Mzay
Jul 6, 2015 11:03 PM
