STS oil feed check valve
Old Jul 29, 2008 | 08:22 PM
2ktransam's Avatar
Default STS oil feed check valve
What is the purpose of the check valve that STS puts on the oil feed line to the turbo? If you don't use it would it cause the turbo to push oil through the turbo seals?
Old Jul 29, 2008 | 09:48 PM
quicksilverado's Avatar
It keeps the oil in the feed line from settling into the turbo housing when the engine is turned off. Without it the truck will smoke like crazy for a few minutes every time you start it up.
Old Jul 29, 2008 | 10:00 PM
dirt track racer 81's Avatar
the oil will actually pool inside the turbo and then run out the exhaust
Old Jul 30, 2008 | 12:25 PM
kbracing96's Avatar
Yep, I'm with these guys
Old Jul 30, 2008 | 02:17 PM
2ktransam's Avatar
Yeah, that's what I figured. I forgot to put it on my new turbo and I think that is wat is causing my oiling problems.
chopperloco
Jul 10, 2016 10:45 PM
Stainless Works
Apr 10, 2016 04:34 PM
Mossyoakglock
Aug 28, 2015 12:49 PM
TAPyvehc93
Aug 21, 2015 05:19 AM
Stainless Works
Aug 4, 2015 12:56 PM
