STS Install Question
Old Apr 26, 2007 | 06:35 PM
Bolo7735's Avatar
Default STS Install Question
I am preparing to install the STS Turbo Kit for my Yukon XL. Looking over the instruction manual (diagram 4 page 12), it talk about splicing into the grey wire from the fuel pump relay. My questions is what is the purpose of slicing this wire? There is no upgrade box that increase voltage to my fuel pump like the boost a pump. I am upgrading to Walbro pump and msd 42# injectors. Also how does the computer know when to deliver more fuel without a FMU? Does Nelson's flashed ECU throw extra fuel at a certain power band to cover the vehicle going to boost? Will the fuel delivery be quick enough to react to the sudden increase of boost? Any help will be appreciated.
Richard
Old Apr 26, 2007 | 07:32 PM
SRT10KLLR's Avatar
Former Vendor
I have a STS turbo on my Ram and I spliced into the fuel pump relay also although it was a different color. It primes your oil pump when you turn the ignition and supplies the power to the same at least on the Rams. The hobbs switch switches the oil pump to high when it reads 1 psi.
Old Apr 26, 2007 | 07:45 PM
Bolo7735's Avatar
Thank you for the help.
Old Apr 27, 2007 | 12:47 AM
speedaddict's Avatar
can you email me a copy of your instructions possibly????
speedaddict@sbcglobal.net
I just need the electrical stuff...PLEASE???
Old Apr 27, 2007 | 11:10 AM
kbracing96's Avatar
Ya, the fuel pump wire is used to operate a relay that turns the oil pump on. The reprogrammed PCM from Nelson is set up to add more fuel and reduce timing when you get into boost. These, PCM are VERY adjustable.
Old Apr 27, 2007 | 12:00 PM
BlownChevy's Avatar
blownerator
25 Year Member
jeff.ellis
Aug 18, 2015 10:34 PM
Denali08
Aug 9, 2015 04:34 PM
USMCvet0311
Aug 1, 2015 07:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
