sts guys need help ASAP?????
Old Jul 20, 2009 | 12:48 AM
gmc6.0's Avatar
Default sts guys need help ASAP?????
hey sts guys i got a huge problem i just had my truck detailed at 3 pm today i picked it up two hours later as i walked up to the truck i noticed that my oil pump was running by the truck was off i figurd they playing with the ignition come to find out that the keys werent in the truck at all.when i go to start the truck the oil pump shuts off... i turned it off and the pump turns on whats going on can some one help me please....the guy said its that he was my engine down with a hose instead of a pressure washer i need help asap
Old Jul 20, 2009 | 12:58 AM
Derek @ EDO's Avatar
FormerVendor
Just retrace your wires coming from your pump, look for loose connections.
Its most likely controlled by a relay, theres a good chance that water may have entered the relay causing it to trip.
As a last resort rewire the pump to an ignition source. Using a relay run pin 86 to a ground, 87 to the + side of pump, the other side of pump to ground.
85 tapped into an ignition activated source.
pin number 30 to the battery or fuse / distribution block
That should fix it
Old Jul 20, 2009 | 01:05 AM
Spoolin's Avatar
GFYS and STFU
Derek don't leave this site...ever!!
I followed what you said but it still impresses me that this site has not turned into a completely useless ***** waving HS braggin forum and still retains some technical know-how peeps!
Old Jul 20, 2009 | 01:19 AM
viciousknid's Avatar
Where's the Beef?
I agree with Derek. But sober up before messing with it.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
