sts guys need help ASAP?????
hey sts guys i got a huge problem i just had my truck detailed at 3 pm today i picked it up two hours later as i walked up to the truck i noticed that my oil pump was running by the truck was off i figurd they playing with the ignition come to find out that the keys werent in the truck at all.when i go to start the truck the oil pump shuts off... i turned it off and the pump turns on whats going on can some one help me please....the guy said its that he was my engine down with a hose instead of a pressure washer i need help asap
Just retrace your wires coming from your pump, look for loose connections.
Its most likely controlled by a relay, theres a good chance that water may have entered the relay causing it to trip.
As a last resort rewire the pump to an ignition source. Using a relay run pin 86 to a ground, 87 to the + side of pump, the other side of pump to ground.
85 tapped into an ignition activated source.
pin number 30 to the battery or fuse / distribution block
That should fix it
That should fix it
GFYS and STFU
Derek don't leave this site...ever!!
I followed what you said but it still impresses me that this site has not turned into a completely useless ***** waving HS braggin forum and still retains some technical know-how peeps!
lxcoupe
Jul 21, 2015 02:12 AM
