STS guys, any tips for installation?
Old Oct 19, 2006 | 07:07 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Default STS guys, any tips for installation?
Ill be installing some of the kit this weekend and the rest next weekend. I have read through the instructions pretty well and I think I have a good understanding of how everything is suppose to go together. Any tips or things that you found made the install go better or things you would different instaling the kit. Besides a lift sicne I dont ahve access to one. How difficult was it to tap the oil pan where it says to. I havent looked at that area of the oil pan thats why Im asking.
Old Oct 19, 2006 | 09:01 PM
adam1803's Avatar
i bought my kit used and didn't have directions to go by and it was still pretty straight forward. Its definetly pretty easy to install so i dont think you'll have any problems.
Good luck with it.
TG02Z71's Avatar
Take the passenger side wheel off and remove the inner fender plastic. It will help you get the pipe oriented better to keep the pipes from rubbing when your tires go lock to lock.
It also is a lot easier to get all the clamps on as well.
The couplers around the MAF blew off on mine after the first run I made, don't be afriad to tighten them up good. I was afraid I'd crack the MAF husing but its tougher than you'd think.
Make sure you run the engine with the oil supply line off the turbo for a minute to get any stray chips or crap out of the hose so it doesn't end up in the turbo. Don't rev the engine with the turbo line off, just let it bleed out a cup or so to make sure the line is clear of debris.
Old Oct 19, 2006 | 09:19 PM
nonnieselman's Avatar
it goes to the oil pan?? i thought it goes to the oil cap?
ive been thinkin of goin with a stand alone oiling system... but thats just me thinkning.
Old Oct 19, 2006 | 09:22 PM
1slow01Z71's Avatar
Return line goes to oil cap, oil feed line goes from next to the oil filter on the pan to the turbo. Standalone oil system would be a MAJOR pita you would still need the pump and you would need a cooler too. Isnt worth the trouble IMO.
Old Oct 19, 2006 | 09:37 PM
Wilde Racing's Avatar
How do I change this text
Do you have a oil cooler for that 6.0? If it just a block off plate It is easier to pull the two bolts and put it in a vise to drill and tap. I also mounted the crank case solinoid thingy to the rear fuel rail bolt rather than the front. Make sure you bolt the ground wire to it!
Old Oct 19, 2006 | 09:42 PM
I was fixin to say,,, the pictures i saw it just bolts up to the block, where the Oil Port boss is..
Old Oct 20, 2006 | 12:32 PM
1slow01Z71's Avatar
bump anyone else?
Old Oct 20, 2006 | 07:21 PM
TG02Z71's Avatar
When you tap that oil block off plate use a smaller drill than the recommended tap drill size for a 1/8-27 pipe thread. The metal is VERY soft and prone to oversizing very easily if using a hand drill or even a drill press. Better tight than loose I say!!
Old Oct 20, 2006 | 08:30 PM
03sierraslt's Avatar
I AGREE If it loose it just means its been abused.
