STS Exhaust?
Old Jan 31, 2010 | 11:47 AM
Badboy464's Avatar
Default STS Exhaust?
The truck is alittle on the loud side, the way my tailpipe is setup theres not much room for a muffler. Which muffler would be the best flowing to put in front of the turbo? Unless there is some way to quiet it down besides that?
Thanks
Old Jan 31, 2010 | 12:05 PM
Badboy464's Avatar
I was looking at the aero turbine muffler. it seems to be pretty free flowing.
Old Jan 31, 2010 | 12:18 PM
Wilde Racing's Avatar
How do I change this text
make sure what ever muffler you use it is a baffle style rather than packing. I installed mine on the other side of the axle after the turbo....
Old Jan 31, 2010 | 12:35 PM
kbracing96's Avatar
I ran a flowtec Warlock on mine back in the day...
Old Jan 31, 2010 | 12:56 PM
slowec's Avatar
I cut a old ford 3.5" diesel tail section up to make a stock exit exhaust with no muffler. Much quieter than dumped. A 3"muffler choked my set up to much.
Old Jan 31, 2010 | 01:49 PM
Badboy464's Avatar
This is the link to that aero muffler.
http://www.amazon.com/Inlet-Outlet-A.../dp/B002TRVGBO
Old Jan 31, 2010 | 05:11 PM
Toomnymods's Avatar
i personally have never liked chambered mufflers, have always been a magnaflow guy.. cant see how a chambered muffler that slows down exhaust flow can be called performance enhancing
Old Feb 1, 2010 | 06:42 AM
Mort's Avatar
I am running a Magnaflow dual 3" in / single 4" out in front of my turbo with a 4" tail pipe. It is a system I got from Grippy for an '03 1500HD. I just split it in two and put the turbo in the middle. Does tend to drone a little at 2500 rpm and I seem to have a lot less turbo whistle. Works for me.
Old Feb 1, 2010 | 11:27 AM
Badboy464's Avatar
I know magnaflow has some straight through designs, but it still has alot of packing that can absorb water. this aero muffler has no packing and is from what I can see a better flowing muffler beacause of the high pressure low pressure chambers it supposedly helps scavenge exhaust gasses meaning it will still spool your turbo faster than a straight through muffler that just creates turbulance. Please correct me if I'm wrong.
http://www.youtube.com/watch?v=iDTTOa77efs
Old Feb 1, 2010 | 11:35 AM
ducky's Avatar
Just run it without. Its not that loud
