sts 67 gone bad?
Old Nov 1, 2007 | 06:14 PM
05crew's Avatar
Default sts 67 gone bad?
well my turbo took a **** tonight! my truck was blowing smoke all the way home, took the air filter off and the barrings are gone and blowing oil in pipes! should i buy a new one or fix the old one???
Old Nov 1, 2007 | 06:24 PM
kbracing96's Avatar
Are you sure the bearings are gone as in the blades hit the housing? If there is just a lot of oil in the pipe, there is probable a problem with your oil return pump. Check the fuse for it. Turbos don't fail very often and when they do then generally lockup or break the shaft.
Old Nov 1, 2007 | 06:27 PM
05crew's Avatar
yes the blades are hitting the housing. the oil is returnin to the motor.
Old Nov 1, 2007 | 08:59 PM
05crew's Avatar
how much is a new gt70 turbo?
Old Nov 1, 2007 | 09:08 PM
Josh, I'll p.m. you a number of a place you can check.
Oh, and what STS calls a GT is not a true GT turbo.
Old Nov 1, 2007 | 09:15 PM
explorer5.0's Avatar
TOTM: November '07
You can get a brand new Master Power T-70 for about $585 shipped. And you can use your current exhaust housing on it so it will be a direct bolt on.
Old Nov 1, 2007 | 10:09 PM
kbracing96's Avatar
If you want to go the MP T-70 route, I got one that's almost new I'd let go for $525 shipped. I've even got the pipe you would need to hook it up to your STS kit. (it has a 2 1/2 outlet instead of the 2" of the 67) I'm running one on my truck and I love it. PM me if you want.
Old Nov 1, 2007 | 11:30 PM
PSM's Avatar
PSM
Sounds like what happened to my buddies wrx. It looks like a locomotive comming down the road. When we too the turbo off, there was as much as 1/2 play in the shaft side to side and the turbine fins had begun to dig into the housing
RustyD
May 23, 2016 07:04 PM
00loudchevy
Dec 3, 2015 05:54 PM
dsbodley
Nov 14, 2015 09:46 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
nabozny21
Oct 17, 2015 07:47 PM
