Stock 5.3 pistons don't like 10 psi
Forged Diamond boost pistons are going in the new motor. 5.3 bored to 5.7, forged rods, rings, arp studs, bolts, 317 p & p heads. Can't wait.
Yep, Dodge 5.7L motors do the exact same thing. Is that the infamous #7 cylinder? My Dodge ate all the drivers side pistons.
You know, the crankshafts are all the same on the 5.3, 5.7, and 6.0L motors. A 4" stroker crank drops right in and is not too expensive these days. A full Eagle 4" crank kit can be found for $2000 or less including custom pistons. Just a thought since it will be apart anyway.....
not the tune, just stupidity
Truck was tuned for 8 psi w/ no methanol. Got a boost controller and a meth kit. Turned boost up to 10-11 psi and it was awesome. Let my nephew borrow it and ran out of meth at high boost. Should have turned the boost down before I gave him the keys. YES...It was detonation, due to no meth. Regardless....I GET A NEW MOTOR !!!!!!!!!!!!!!!!!!
Originally Posted by BlownChevy
Dont think that is boost, that is detonation. Chaulk that up to a bad tune.
I remember Parish stuffing close to 20psi into his original 4.8L to see if it would cry for mercy. The motor lasted longer than his meth and patience. Course that was on good gas and lots of vital engine monitors keeping things in check, ie a great tune.
I agree with others, since you already have it apart, put in a forged crank too. I think you'll wish you had.
