Stall RPM to properly load the turbo?
Old Sep 23, 2006 | 11:06 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Default Stall RPM to properly load the turbo?
6L cammed, sts wtih gt67, fmic, 3.73s with 30" tires. I will be using a 2-step out of the hole and a transbrake once the 80e goes in. Street weight is about 5300#s. I want the best rpm for coming out the hole but still keep the turbo loaded after the shifts. Im not worried abotu driveability as this is not my DD just a toy so...
Figured this topic was more suitable in the FI section then the Drivetrain section.
Old Sep 24, 2006 | 06:42 AM
cablebandit's Avatar
9 Second Club
with a t-brake, you wont need much stall....i'd guess a 3000 would work....i got a 2400
here is a vid in the driveway http://incontt.net/videos/t-brake.wmv
Old Sep 24, 2006 | 09:52 AM
1slow01Z71's Avatar
18#s of boost
I already got the two step now I just need to get 80e from transformance and Ill be set
Ill try a 3K for now then when I go 80e see if I need to adjust it at all.
Old Sep 24, 2006 | 10:43 AM
1slow01Z71's Avatar
Would it be worth going to 3.42s from 3.73s to help load the turbo. Keep in mind Im 4wd. I can pull the front diff myself and wouldnt cost too much to get the gears set up. The rear isnt a problem since Im going to a 14 bolt. I gotta check and see if that ratio is even available in a 14 bolt also.
Old Sep 24, 2006 | 05:15 PM
Stoichiometric's Avatar
I have only seen factory 3.73s and 4.10s in a 14 bolt. There is probably an aftermarket set for a 3.42 out there.
I had a similar question about the gear ratio vs. stall; if you have 4.10 gears and a low stall will the truck respond similar to 3.42 gears and a high(er) stall?
Old Sep 24, 2006 | 08:21 PM
1slow01Z71's Avatar
I have done ALOT of reading on tech and even posted a thread and the general consensus is that it will help. Once I get the 418 back in Im sure I wont lack any low rpm power so Im going to switch to 3.42s. Im still checking all sources right now.
Oobray
Jun 13, 2022 03:38 AM
LCHEE
Oct 24, 2020 04:10 PM
silver-mod-o
Jul 27, 2015 05:24 PM
Ammadien
Jul 22, 2015 08:50 PM
NuckenFuts
Jul 9, 2015 08:45 AM
