Spark plugs for supercharged LQ4
Old May 22, 2015 | 04:24 AM
mikeskiw's Avatar
Default Spark plugs for supercharged LQ4
what plugs would you guys recommend for a supercharged LQ4? Heads are 317 castings, they don't look like taper seat but I could be wrong. It's a new motor so I don't have a reference from old plugs to go by.
Thank you for the help.
Old May 22, 2015 | 06:41 AM
Byrdman11's Avatar
More info would be nice. But you can start with a 6 heat range on a mild setup.
Old May 22, 2015 | 07:07 AM
Three6GMC's Avatar
What ^^^ said throw some NGK TR6s in there do a couple pulls then read the plugs.
Old May 22, 2015 | 08:04 PM
mikeskiw's Avatar
I've been running NGK TR6 and NGK TR6ix in the old 5.3 mill that's getting replaced. I may bump the boost up from 5 to 7psi with a pulley change if needed to hit my target HP number. When I changed them they looked pretty good so that's where I will start. If the heat range looks good I'll swap in the ix tipped after 20k miles.
Thx!
SlvrSierra4.8
Oct 1, 2015 09:39 PM
FormulaZR
Sep 14, 2015 05:23 PM
cousblake11
Sep 9, 2015 06:52 PM
zraffz
Sep 8, 2015 07:40 PM
