Some opinions on turbo size needed
Old Apr 20, 2010 | 03:40 PM
Bluchevypick's Avatar
Default Some opinions on turbo size needed
I have been seriously contemplating on building a rearmount turbo setup for my truck. The question i have is what would be a good all around turbo for my setup. My setup is in my sig. I want to run around 10 lbs of boost around town and possibly up boost at track but most of all i want a good all around good running setup.
Old Apr 20, 2010 | 04:15 PM
f4tal's Avatar
T76, good amount of power, not as much lag, you can get em cheap.
Most of all will be tuning though!
Old Apr 20, 2010 | 07:46 PM
Sleeper04's Avatar
Yep, I'm running a T76 with close to the same set up as you and it's great! You'll need bigger injectors and fuel pump for sure. I'm running out of fuel on the higher boost setting (14#) since the single Walbro isn't keeping up. You can get a new MasterPower T76 for around $750 new.
Old Apr 20, 2010 | 08:39 PM
kbracing96's Avatar
Yep, a MP T76 would fit the bill nicely, let me know if I can help you.
Old Apr 20, 2010 | 11:17 PM
2ktransam's Avatar
If you are only looking to only run 10psi I would go with a MP70. I have had a MP70 and a TC76 on my rearmount and the mp70 is a better street turbo for a rear mount. The tc76 is awesome for power but it can be a little laggy. If you plan on turning up the boost later go with the 76.
Old Apr 21, 2010 | 02:17 PM
Thanks for all the input guys. After talking to Kyle for awhile last night im opting for the t70 on around 10 lbs on street and maybe 15 at track.
Old Apr 21, 2010 | 05:14 PM
2ktransam's Avatar
I think you will be happy with the mp70 on a rear mount. The 76 is sweet for top end but it is laggy as hell. You should be able to run some good times if you turn it up to 15psi.
Old Apr 21, 2010 | 06:39 PM
Sleeper04's Avatar
This depends mostly on trim and A/R. I've run a T76 with a .96 and .68 and the .96 definitely was pretty laggy. With the .68, it's almost instant boost and great for the street. I also have the P trim which also helps reduce lag.
TAPyvehc93
Jul 23, 2017 10:54 PM
ZONES89RS
21
Sep 24, 2015 05:58 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Aboss
Jul 9, 2015 10:28 AM
jrplz
Jul 9, 2015 12:07 AM
