Sold the PTE 76GTS...no more race truck!
No more big turbo on the little engine!!
So far I've had a MP70 with a .81 a/r, made 617/623@ 15psi with manual, went 11.33@122 at 18psi (auto). Then with the PTE 76GTS .96 a/r went 10.88@125 at 18psi and then 10.75@127 with dry 50 added.
Next snail I hope will run around 128-129 at 10.5's @ 20psi and spool a little earlier to help get the boat down the road... Any guesses? Hint it's a Magnum turbo...
Couple shots
So far I've had a MP70 with a .81 a/r, made 617/623@ 15psi with manual, went 11.33@122 at 18psi (auto). Then with the PTE 76GTS .96 a/r went 10.88@125 at 18psi and then 10.75@127 with dry 50 added. Next snail I hope will run around 128-129 at 10.5's @ 20psi and spool a little earlier to help get the boat down the road... Any guesses? Hint it's a Magnum turbo...
Couple shots
I plan to swap out ls6 springs. I likely never got to see the real power the 76gts had because of the light seat pressure. I think after about 13-15psi area their done. Other then that though, same setup and correct on the arps and cam.
