Sock bottom end 5.3 and MP122HH...How much boost to be safe?
Old Feb 22, 2010 | 09:22 PM
exodus's Avatar
Well the key here is to be on the safe side for the initial tune, and the "original target" here was going to be 7-8 psi. S based on what I am seeing the 3.2 will get me very close, and I can see how it is, and then maybe venture to the 3.0 from there.
Old Feb 22, 2010 | 09:23 PM
JennaBear's Avatar
Truck Sponsor
That would be my suggestion.
Old Feb 22, 2010 | 09:25 PM
exodus's Avatar
ok cool, thanks. sent you a pm as well on another question
Old Feb 22, 2010 | 09:37 PM
RedHot04's Avatar
Gotta a SOCK on the bottom end??!! JFWY...9-11 psi you will be fine as long as the tranny will hold out. Just keep the temps down, the oil changed and KR in check. Rock on with it...and don't dog it at every stop lite!
Old Feb 22, 2010 | 09:43 PM
exodus's Avatar
Temps and oil is no problem, but I am not tuning so the rest is in the hands of wheatley lol
Old Feb 23, 2010 | 10:48 AM
SuperchargedSS's Avatar
just make sure you are using the appropriate pulley. When I bought Grip's kit, I had 4 8-rib pulleys to use with it. I know the offset of the snout doesn't allow a standard maggie pulley to be used with it. The pulleys I had for it were custom made.
Old Feb 23, 2010 | 12:00 PM
LsxCody's Avatar
you should be fine with around 11 -12# if the tune is good
Silveradorst07
Dec 31, 2015 12:04 AM
thunder550
Oct 8, 2015 04:53 PM
OLD BULL
Aug 1, 2015 05:00 PM
Ls3silverado
Jul 31, 2015 04:22 PM
kdw8888
Jul 9, 2015 10:52 PM
