So 10psi is max on a stock engine...
So this will happen on the #7 even if one is using a Radix, wich cure the #7 problem by a better manifold desing? (or so one has been informed elswere on this forum.)
Looking at the piston, it does not look anything near as a ping-meltet Saab piston looks.
There fore I draw the conclusion that the combustion pressure simply "drives the piston beyond it´s specification", to the point of disintegration.
i.e. this is not a ping/knock problem.
Correct?
Correct?
Originally Posted by nightrunner
how exactly do you plan to get 12-16psi on a 5.3 with a radix?
right now the only way to do it is a MP122HH, and im not sure on that
The 112 would do it if the factory parts would support it. 5.4L lightnings are running 16-17 psi.
Correct?
Correct?
You can run more than 10psi, but do it on a daily basis with 10-15000 miles a year and expect problems. The two vehicles mentioned above are not driven daily, and I think that's an important factor when saying if it'll live or not. Seeing 20psi daily is a lot more taxing than once a week or twice a month.
Either way, your tune has to be dead on ***** accurate.
GFYS and STFU
Originally Posted by vanillagorilla
...Either way, your tune has to be dead on ***** accurate.
