snow boost kit
Old Sep 14, 2006 | 07:57 PM
sparkwirez06's Avatar
Default snow boost kit
I picked up a snow boost kit #50012 for the 6liter powerstroke. I want to put it on my LS1 running 6-10# boost, it has a 220 psi pump, the controller is a vc-100 will this work in my application? the controller has start psi #clockwisestarting at 9:oclock position,of 6,15,25,and 30. the full psi is 15,22,50 and 70?? THANKS
Old Sep 15, 2006 | 08:40 PM
anybody familliar with these controllers? on at 6 full boost at 15??? THANKS,
[url]http://www.turbols6.com/gallery/view_album.php?set_albumName=TYPHOON-LSX-TURBO]
Old Sep 15, 2006 | 11:11 PM
camcojb's Avatar
maybe give them a call.
http://www.snowperformance.net
Jody
Old Sep 16, 2006 | 07:23 PM
thanks, i tried that,left a message,no return call?? that was thursday,i'll try tommorow.
Old Sep 18, 2006 | 12:08 PM
twinturboc10's Avatar
The start psi is where the pump will turn on at. The full psi is where the pump will be at full speed. If full psi is less that start psi, the pump will run at full speed when full psi is reached. It should work fine, bu will have less fine adjustability that the lower pressure gas models have. The dials can be set at any position (don't have to line up with the numbers).
Old Sep 18, 2006 | 07:04 PM
THANKS, i got a reply from snow today, the controller has a 100psi map sensor, of course they want to sell me a maf controller, I'm going to try it, it's just a spray control not a boost control, THANKS again
GXPJAY
Feb 13, 2022 08:15 AM
greedygenius
Sep 3, 2015 06:51 AM
Ketis
Jul 23, 2015 12:37 PM
Deceptarado
Jul 8, 2015 05:24 PM
