Slick little oil feed adapter..
Old Sep 8, 2014 | 11:25 AM
brewster240's Avatar
unless you were just saying in general. depends how i read your reply lol
Old Sep 8, 2014 | 12:03 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
The oil pressure sensor "sees" oil before any of the engine bearings, lifters, etc. All modern oil filters have anti-drainback valves. So the concern of "late lubrication" is a non-issue.
Old Sep 8, 2014 | 02:38 PM
tim wellington's Avatar
Default oil first
Originally Posted by BlackGMC
Interesting. Isn't that spot at the very end of the oil path in the motor? I would rather feed my turbo from a spot that is closest to the oil pump (spot above the oil filter) rather than a spot furthest away...
i agree and tested IT. i got oil pressure from the fitting above oil filter before oil pressure switch .both ways with my home made primer and with the oil pump .And pressure was HIGHER........... TESTED before my new install in may
Old Sep 8, 2014 | 05:30 PM
Three6GMC's Avatar
i have my oil feed tapped into the oil pressure sensor mount with no issues basically same place so you won't have any pressure issues getting your feed there.
Old Sep 9, 2014 | 08:25 AM
Razor's Avatar
BMF
What were the numbers?
Old Sep 9, 2014 | 08:43 AM
TIM Z's Avatar
11 sec. Truck Mod
Cool thanks for sharing , and thanks for the schematic Roger :thumbs:
Old Sep 9, 2014 | 12:18 PM
Default oil pressure
at oil pressure switch 50 to 62 at oil filter side mount 75 to80's higher number were with my home primer.
cheyenne383
Nov 13, 2015 09:24 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
GMCtrk
Oct 20, 2015 06:17 AM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
