Single 4 inch exhaust set ups ?'s
Old Nov 29, 2015 | 10:35 AM
sharpshooter's Avatar
Default Single 4 inch exhaust set ups ?'s
What exhaust set up did you have prior to the single 4" and do you have any dyno or track performance to show what the change did?
Old Nov 29, 2015 | 11:47 AM
03sierraslt's Avatar
I had a single 3" and went to 4"
Lost 1-1.25lb boost and my back pressure went from 10-12lb to 0
No direct comparison as I had not been to track for a couple years.
It without a doubt increased topend pull, my 3" exhaust sounded like a huge air leak at wo.
Old Nov 29, 2015 | 03:07 PM
Vortec350ss's Avatar
Unfortunately I don't have anything to compare either. I went 4" before I even knew for sure I needed to and I haven't looked back.
Old Dec 1, 2015 | 12:06 AM
iregret's Avatar
Charlie Murphy!
I haven't researched it much, but is there an easy 4" exhaust setup or has everyone went custom? I've got a 2000 RCSB. What's the best/affordable solution?
Old Dec 1, 2015 | 12:09 AM
GMCtrk's Avatar
Mine is MBRP for a duramax, it was a directly bolt in.
Old Dec 1, 2015 | 05:52 AM
TrickTurbo's Avatar
Truck Sponsor
MBRP is very affordable.
My rcsb uses it. I added 1 hanger to help hold mid line.
4" is a close fit in some areas.
Old Dec 1, 2015 | 08:42 AM
Choda's Avatar
I only have 4 inch over the axle and tail pipe but going from a pos 3 inch exhaust to a real setup with good muffler and tail pipe made a world of difference on my truck.
And it looks badass. =]
https://www.performancetrucks.net/fo...-after-524031/
Old Dec 1, 2015 | 09:27 AM
The issue us non turbo guys have is that most diesel exhaust systems are incredibly loud without an exhaust snail in line... The MBRP will be no exception. You will likely have to add a second muffler in line.
Old Dec 1, 2015 | 12:31 PM
GMCtrk's Avatar
Correct. The little diesel muffler it comes with is useless.
Mine was replaced with a massive magnaflow 30" diesel muffler
Old Dec 1, 2015 | 04:48 PM
TrickTurbo's Avatar
Truck Sponsor
My MBRP came with a huge muffler.
Besides NA / blower with 4" is a waste of money.
