significant increase in boost...why?...how?
Old Dec 20, 2006 | 08:57 AM
Superado's Avatar
11 Second Truck Club
Default significant increase in boost...why?...how?
Originally Posted by Superado
went WOT from a roll this morning...45 degrees outside...tranny downshifted...afr went to 11.5...boost jumped in at about 6 #'s...started climbing again...thought last time was a fluke...thought that it would peter out at about 8 #'s...NOPE...climbed to 7...8...9...10...11...12...I got out of it...wtf!?!
I am confused!
I thought by freeing up the exhaust that I would probably lose a pound of boost...which was 8 #'s w/ cats...
spoke w/ ProCharger...they said they didn't have an answer for me...
the first thing they said was that I had a major restriction somewhere...asked me if I changed muffler when I got rid of cats...NOPE...
someone else asked about the blow-off working...but hell, if it wasn't working properly I wouldn't see increased boost @ WOT...and anyways, I can hear it when I let off...
https://www.performancetrucks.net/fo...7&page=3&pp=10
Old Dec 20, 2006 | 11:26 AM
TURBHOE's Avatar
are you sure they didn't screw something up when they put in the pipes inplace of the cats? did you gain any power with the added boost?
Old Dec 20, 2006 | 11:35 AM
Superado's Avatar
not sure but doubtful...same guys that fabbed my inlet to tb...haven't dyno'd it but sotp meter feels great...it was climbing when I backed out of it @ 12#'s on the gauge...
Old Dec 20, 2006 | 11:43 AM
dewmanshu's Avatar
Moderately Differentiated
I felt a HUGE, I mean A HUGE diffeence from 9#'s to 10#'s. Did you feel like you were in a rocket ship at 11#'s? Should of started pulling it's *** off after 9#'s. Otherwise...something else is wrong if it wasn't pulling like a monster IMO. Gauge reading messed up? Something simple?
Old Dec 20, 2006 | 12:01 PM
Superado's Avatar
the gauge seems to be working fine under daily driving though...experiencing same vac/boost levels that I always have...I dunno...
Old Dec 20, 2006 | 01:44 PM
Superado's Avatar
I thought of one other change I made between the two boost levels...installation of a 160 degree thermostat...
Old Dec 20, 2006 | 01:55 PM
XLR8NSS's Avatar
Adkoonerstrator
I was thinking gauge problems too. Anyone around you can borrow another gauge from or do you have a small pump of some sort with a gauge on it that you could test your truck gauge against?
Now that it is cold in the morning up here I do see about 1-1.5psi more boost than I did at the end of summer. I can't imagine a difference of 4+psi due to weather though.
Did you put a new belt on it or anything? Is the truck running rough at all, maybe a bent pushrod or collapsed lifter not opening a valve all the way creating a "backup" in the intake?
Old Dec 20, 2006 | 02:16 PM
NubzSS's Avatar
the same thing happend with my truck after the exaust work. i've hit 11lbs like 5 times now. it dont do it all the time but i gess if the temp is right it likes it.
Old Dec 20, 2006 | 02:35 PM
slowec's Avatar
Maybe your procharger was designed for a stock exhaust and too little backpressure is causing extreme boost creep. What other restrictions are in your exhaust? Muffler? You may need some backpressure to maintain normal boost readings or tune for the 13#'s your now getting
Old Dec 20, 2006 | 02:41 PM
Superado's Avatar
Magnaflow SS single-side cat-back...that's it...
Jerry has pointed out that maybe the huge difference was due to the extreme change in temp and the fact that I have small 2-core IC...he checked one of my "with cats" logs that showed me starting @ 104 and ending up @ 158 at the end of the 1/4...and maybe if I had a larger IC before, that there wouldn't have been such a wide range of difference now...also, my IC is mounted parallel to the ground with no sort of air dam on it...
