Should I bother to go from 7 to 10psi?
Old May 30, 2013 | 07:16 PM
  #31
03 BLKTAHOE's Avatar
I believe its about 20 rwh for every 1psi increase so with no other mods like meth etc. I think you would see about 60 rwh.
Old May 31, 2013 | 08:55 AM
  #32
Vortec350ss's Avatar
Do they make smaller pulley's for all the accessories to accommodate for the overdriven crank pulley? It just seems that some thing would be spinning unnecessarily fast given the higher idle with a cam, higher redline, and a 10% increase. I'm just thinking if you are upgrading to an 8 rib anyway why not correct the issue all around... what the hell do I know though.
Old May 31, 2013 | 11:57 AM
  #33
JCunningham's Avatar
so If I do injectors and put a 2.80" pulley on I should be around 10psi? It will not require meth but would be a good idea? I have a 108.75" belt on now with going from a 3" to 2.8" require me to get a smaller pulley? I have a adjustable idler pulley.
What is the limit on IATs how hot befor I should worry? I dont think I can do meth right now.
Old May 31, 2013 | 12:01 PM
  #34
smokeshow's Avatar
Mod with training wheels
Just make sure it pulls timing with higher IAT and you have nothing to worry about. I had close to 200 degree IATs at the track here last year just because the ambient temp was so high, but pulled about 10 degrees of timing to account for the heat. Never had an issue. It just makes you slower til you cool back down lol.
Old May 31, 2013 | 12:05 PM
  #35
ok cool
Old May 31, 2013 | 01:09 PM
  #36
nonnieselman's Avatar
Yea mine was the same way.. 80* ambient and some heat soak my IATs hit 165* at the end of the track. mine pulls about 10* at that point also.
Old May 31, 2013 | 02:48 PM
  #37
NemesisC5's Avatar
Originally Posted by Mike @ New Era
It's a 6.2, pretty sure there will be pretty close to a 75 hp gain from 2.5 psi, and meth. You gotta get rid of those cats though.
Mike, are you saying "get rid of the cats" because the meth will ruin them or because the cats are a restriction?
Old May 31, 2013 | 03:53 PM
  #38
Both im sure..
BCraven1018
37
Dec 20, 2016 11:46 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
fortune46x
Sep 16, 2015 08:18 AM
Jake99
Aug 8, 2015 07:56 AM
