A second set of pistons gone...
Old Jan 21, 2015 | 02:26 PM
  #31
lhenrichs's Avatar
Originally Posted by AKlowriderZ71
A 2002 Silverado stock fuel pump will not provide enough fuel for your FI setup, regardless of which injectors you have, and regardless of what your wideband reads.
If we could see pictures of the damaged pistons, it would help us troubleshoot your failure. Broken/damaged parts usually tell you what went wrong.
I'll see if I can get a picture up here of this last failure today.
Old Jan 21, 2015 | 07:15 PM
  #32
lhenrichs's Avatar
This is both sides of the piston.
Attached Thumbnails A second set of pistons gone...-image0.jpg   A second set of pistons gone...-image0-1-.jpg
Old Jan 21, 2015 | 07:18 PM
  #33
AKlowriderZ71's Avatar
11 Second Hall Moniter
Post a pic of the top of the piston. Would also like to see close ups of the ring lands.
Old Jan 21, 2015 | 08:18 PM
  #34
sTNT971's Avatar
I'm going in my 5.3 truck with this set up
6.0 heads ported , ARP studs , MLS gasket , custom camshaft (valve train)
fuel system : injectors 88lb , booster pump , the fuel rail come with my holley intake , regulator , dual fuel pump out line044 with under car surge tank and devilsown meth/water kit
about the piston i see Lil johns motorsport have pistons for 3.78 bore its custom piston u can ask him to give u more info
he is good guy .
Old Jan 21, 2015 | 08:50 PM
  #35
dirt track racer 81's Avatar
Post a pic of the orientation of the rods on the crankshaft
Old Jan 22, 2015 | 07:41 AM
  #36
Gadgetized's Avatar
Can you take pictures of the cylinder? How certain are you the ring orientation was correct? If you are building boost and the rings are lined up it will create a lot of heat. In both pics I cant see either top ring gaps. I can only see one gap on the oil ring, where is the other? How much did you hone it? What I wonder is if honing caused a sharp lip on the bottom of the cylinder wall, and every time the piston skirt came out of the hole it shaved off some material. Is all of the scoring on the bottom of the cylinder? The top of the piston looks OK from your pics(meaning it doesn't appear to be a heat issue), it looks more like a machining issue.
Old Jan 22, 2015 | 08:20 AM
  #37
lhenrichs's Avatar
The tops of the pistons were all perfect. The rings were all turned correctly with the top ring gapped to the inside and 2nd ring gapped to the outside. I had turned these rings to see if they were right in the grooves. The scoring was pretty consistent throughout the wall. I made sure when I was honing that I was doing the whole cylinder evenly. The truck is in the shop at my dad's so I might not be able to get any more pictures for a day or two.
I had a guy tell me that these pistons don't expand as much as other pistons and the skirts were too loose. Other people are saying that they were too tight and that's what caused this issue.
I did find out that I have a fuel problem. I decided to search if there was a fuel issue since a lot of you guys had been saying that. The injectors that I bought were sold to me as 52lb/hr injectors. I pulled the part number off of them and discovered that they are actually the 8.1 truck injectors meaning 31-32lb/hr injectors. I hate dishonest salesmen. I guess I know from now on the check stuff like that.
Old Jan 22, 2015 | 09:50 AM
  #38
George C....'s Avatar
Formerly ScreamingL
What were ring gaps
Old Jan 22, 2015 | 10:05 AM
  #39
It seems as though you have multiple issues to resolve here.
Fuel system, injectors, piston-to-wall clearance(depends on piston material & application), ring gap(also depends on material & application), and the condition of your cylinder bores in the block. Maybe more that hasn't come to light yet.
Don't forget to clean the oil galleries in your block. They hold lots of metal.
Old Jan 22, 2015 | 11:37 AM
  #40
Atomic's Avatar
I have a gauge for that
Just to clarify, BB is a good tuner, but there are fundmental problems with tuning a turbo setup via mail. You miss a lot of details when you arent there in person to hear and feel the engine.
What do the plugs look like?
