seafoam question
Old Sep 11, 2010 | 09:12 PM
terravast4's Avatar
Default seafoam question
If i want to use seafoam on my maggie 112, can i use the pcv port on the back of the j-tube? How, exactly , do you do it? Thanks.
Old Sep 11, 2010 | 10:42 PM
WorkTruc's Avatar
I would not use it thru J tube as Radix rotors are coated and you may loosen that coating.Your safest route with Radix is to add to gas tank as it will bypass rotors and clean injectors and top end.
Old Sep 11, 2010 | 11:02 PM
joeyc125's Avatar
11 Second Truck Club
suck it in where your boost gauge is hooked up, that will be after the rotors. I would do it through the pcv myself. Many others, including myself have ran methanol through them which is much much more corrosive than sea foam without any ill effects.
Old Sep 12, 2010 | 12:30 PM
terravast4's Avatar
so with the truck running just stick the vac line in the container and suck in a little then shut it down for a while?
Old Sep 12, 2010 | 08:04 PM
joeyc125's Avatar
I just put about half a can of it in a clear container and suck it through, listen to the motor and make sure you don't bog it down so it dies. I have done it through the FPR vacuum hose, its small enough so it can't suck it in too fast.
Old Sep 12, 2010 | 08:57 PM
terravast4's Avatar
thanks. you notice a difference after?
JordanH
Dec 25, 2015 08:32 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
andrewlong
Sep 8, 2015 10:25 PM
