seafoam question
suck it in where your boost gauge is hooked up, that will be after the rotors. I would do it through the pcv myself. Many others, including myself have ran methanol through them which is much much more corrosive than sea foam without any ill effects.
I just put about half a can of it in a clear container and suck it through, listen to the motor and make sure you don't bog it down so it dies. I have done it through the FPR vacuum hose, its small enough so it can't suck it in too fast.
carid
Sep 10, 2015 09:07 AM
