SCOL ported blower snout
Old Jan 13, 2020 | 03:39 PM
terravast4's Avatar
Default SCOL ported blower snout
For anyone interested Superchargers online sells these ported blower snouts for the TVS blowers. Looks to be good quality.
Old Jan 13, 2020 | 03:45 PM
dantheman1540's Avatar
I was just googling ported blower snouts this morning. You've got me really wanting one now. Are the pictures your personal one?
Old Jan 13, 2020 | 03:48 PM
terravast4's Avatar
Yes. Just got the snout and the nick williams “ boosted” 102mm throttle body today.
Old Jan 13, 2020 | 07:15 PM
03sierraslt's Avatar
How well does the porting match the throttlebody if you open the blade and compare? I hope you have better luck with that throttlebody then I did.
Old Jan 13, 2020 | 08:34 PM
terravast4's Avatar
The porting it matched to the 102mm throttle body. I guess we shall see with the throttle body. I think under 14 psi it may not have issues.
Old Jan 14, 2020 | 09:12 AM
MikeGyver's Avatar
There's a lot of info missing between Pat saying that he had problems with that throttle and you saying the issues were boost related.
Is your supposition based on his experience, or just your own wishful thinking?
Old Jan 14, 2020 | 10:01 AM
terravast4's Avatar
I consulted with Allen Nelson about a recommendation based on his experiences because i had seen mixed reviews based on my research. Allen said he had used NW throttle bodies with success but he had seen some defective units. I have read that people have had greater luck with the “boosted” NW units.
Old Jan 14, 2020 | 10:05 AM
terravast4's Avatar
Just to clarify the majority of failures of the NW throttle body were people running boost in excess of 14 psi. This is just through my research of many threads from numerous sites for vettes, gto as well as trucks. Most failures i saw to be around 16-17 psi or greater.
Old Jan 14, 2020 | 10:06 AM
The main problem seems to be anything P59 ecm based when used with the weaker LS3 tb motor. I tried 2 “boosted” NW102’s and they were both the same. If you logged TPS and commanded TPS you could see the blade being sucked closed. Newer ECm’s allow you to tune around it much better but it isn’t fixed. If you watch some blower dyno videos you can see the issues on many setups, they just tune around it.
Old Jan 14, 2020 | 10:07 AM
while this is most likely true, the throttlebody doesn’t know boost. Only airflow, so that’s the main factor.
