Sc H2 wanting a little more
Ok of course I am like everyone else.... I have a supercharged H2 that I thought would be fine, well now I want a little more. The only mods besides sc are shorties, cat back, electric fans, cia, and nelson tuning.
Now for the questions:
I am at 6# , what can I go to without being to much ( I do some light towing)
How much would 90mm help out?
High flow cats?
Torque coverter?
Or any other suggestions?
Thanks alot,
Tim
High flow cats?
Torque coverter?
Thanks alot,
Tim
Running Moregrip's old 112. I don't need it to be a 12 second truck but wouldn't mind a little more than what I have. Kinda was figuring all the little things without having to redo the engine yet.
Thanks,
Tim
Thanks,
Tim
Thanks,
Tim
Thanks,
Tim
Well I don't mind having Nelson retune for whatever. What pulley size should I try? I will have to check and see what I have on it now, but I get 6# max.
Thanks,
Tim
Thanks,
Tim
Thanks,
Tim
Thanks,
Tim
Prepare for transmission work now. You have a 4L65E and it won't like much more than the next pulley you'll install. The good news is a shift kit and the billet servo's will get you by down to a 2.9 pulley. Also ask your transmission builder about the vacuum modulator kit for your transmission. It's a life saver and allowed me to run down to 13.86 in my H2.
You don't have to sweat any other parts of the driveline unless you go with a lot more power than the Radix can make. Even a 2.75 pulley won't hurt anything other than the stock transmission.
I expect to retain my fully built 4L65E down to mid 13's... we'll see what happens.
You will need a good tuner as well. You might find you need injectors if you go below a 2.9 as well. I did.
