Same boost drop but new question
So I am getting my tune back together with the Z06 cam and I have a question. On high boost it shoots up to 8-9psi and holds strong until about 5k rpms and then it falls off to 7psi until redline. I want to run 10psi on high boost but I am afraid that it will spike to 11-12psi and then settle to 10psi in the upper rpms. What should I do? Should I turn it up to 11-12psi and let it settle to 10 or stick with 10psi through the mid range and let it fall to 8-9? I don't want to break anything but I want to get as much as I can safely.
I am tuning it myself and I am still 1 bar.
How do I change this text
I have not contacted STS about this problem but everyone seems to think it is pretty normal due to running a light spring for low boost. Parish thinks that it is back pressure pushing open my wastegate due to the weak spring and small turbo.
I am trying to keep my tune pretty safe. I have it tuned for 18 degrees of timing for low and high boost and have not seen any knock. I am running 11.8 AFR on low boost and 11.0-11.4 AFR on high boost with 50/50 meth/water.
According to Wild Racing the 60-1 should support 10psi pretty well. I think it is a problem with the wastegate since it does the same thing at 5.5psi. I did some research last night and a lot of the import guys have the same problem at high rpms but I couldn't find a good fix for it.
dont forget psi level is irrevliant {sp}. do you have a EBC or you using a manual one? i would look into the wastegate issue also see if you ahve anythign that could be choking the turbo. I think spoolin has issues of boost dropping off in higher rpms. his A/R is too small and choking the motor
