?s Eletronic Boost Controler.
Old Feb 5, 2009 | 06:51 PM
Stampede4ever's Avatar
Default ?s Eletronic Boost Controler.
How does the STS system control the boost controler?
I was thinking of using a Window switch. Would this be posible, and what voltage would I need? I'm thinking 12volts.
Also, would anyone be interested in a Eletronic Boost Controller?
Thanks.
Old Feb 5, 2009 | 06:53 PM
FrostKing's Avatar
STS uses a switch to open and close a solenoid to a pnuematic regulator. This will apply pressure on top of the wastegate spring. Works good and costs around $5.
Old Feb 5, 2009 | 07:19 PM
What is $5.00 bucks, the regulator or the boost controler?
Thanks.
Old Feb 6, 2009 | 02:49 PM
Mort's Avatar
The switch????.....LOL
Old Feb 6, 2009 | 05:36 PM
FrostKing's Avatar
Thanks.
Regulator = $5 (AKA boost controller)
Switch = $0.50 (high/low boost selection)
Most of the digital boost controllers out there are overkill on a large displacement, low boost setup. 30psi on a 2.0L motor is a different story, though.
Old Feb 9, 2009 | 01:38 PM
Does anyone have a link to switch?
Thanks.
Old Feb 9, 2009 | 07:28 PM
FrostKing's Avatar
Any switch, your choice. I have 3 blue lit rocker switches all the same. (fog lights, meth pump, hi-boost)
Old Feb 10, 2009 | 04:58 AM
What I should have asked, where to find the valve at, to switch from low boost to high boost?
Thanks.
Old Feb 10, 2009 | 04:40 PM
ILuvJDM's Avatar
get a Greddy E-01, I loved it
overkill? yes.
Old Feb 10, 2009 | 06:45 PM
FrostKing's Avatar
You can find a 3-way pneumatic solenoid at a HVAC supply house or heavy duty automotive supply. Just make sure the coil is for 12v.
