?'s about STS on my 8.1
#45
The tranny should be fine, it is strong piece and odds are you are not going to be punching it everywhere you go everyday. The diesel guys break them because they are making twice as much torque. 600tq vs 1200tq on a modded diesel. U can go with the kit for piece of mind though.
#46
I am running the 60#'ers in my setup. I maxed the 42's out real quick...dont waste your time with those if your boosting past 4-5psi. Just to give some perspective, this is my setup:
496c.i. (obviously)
Allison 5spd (no mods)
60lb injectors
Stock pump
Corsa touring exhaust
stock fuel pump
417rwhp
511rwtq
Today i saw my IDC's hit 70% on the 60lb injectors @ only 6psi. My EFI log shows a lean trend in boost. No matter how much i add fuel to the VE table it still stays a little lean. I am coming to the conclusion that i need to upgrade the pump in the tank now to get back to a safer AFR. It will most likely increase the IDC a few percent when I do this as well. If it were me, and you plan to go beyond 7psi with your setup....I might consider a fuel pump upgrade and even a bigger injector than the 60's. Just my opinion though......they say after 80% IDC, you should be looking to upgrade. I drove my 42lb'ers well over 100% for almost 2 years. Its your call. What year is your truck? Do you have a return or a returnless fuel system?
On a side note, when you upgrade the injectors....do a search for my injector thread. It was an interesting upgrade to say the least...the fuel rails on the 8.1L are nothing like the small block fuel rails. You could lift the engine out of the engine bay by straping on to those suckers....seriously!
496c.i. (obviously)
60lb injectors
Stock pump
stock fuel pump
417rwhp
511rwtq
#47
And why are the rails like this? Should I take it to a profesional to get them done?
#48
You have the return style (thats good) on your setup if its a 2002. No professional needed.....just a vise, some wood scraps, and a little arm strength is all thats needed.
Check out the thread......start at post #96
https://www.performancetrucks.net/fo...=412549&page=3
#50
496c.i. (obviously)
60lb injectors
Stock pump
stock fuel pump
417rwhp
511rwtq
496c.i. (obviously)
60lb injectors
Stock pump
stock fuel pump
417rwhp
511rwtq
We had a problem with my truck showing lean on top too. My buddy found an table that was limiting max fuel.
