?s about log headers.
Old Oct 22, 2010 | 02:54 PM
Stampede4ever's Avatar
Default ?s about log headers.
I plan on building log headers, using 0.06" mild steel for both banks. Should I be concerned about anything, and how long will they last, ball park? And would having them coated help, if so, who?
Thanks.
Old Oct 22, 2010 | 03:05 PM
iamkeniff's Avatar
just spend 500 on a KBracing log...just throwing it out there
Old Oct 22, 2010 | 04:40 PM
TrickTurbo's Avatar
Truck Sponsor
Thanks.
Over time it will crack. timeline depends on boost, backpressure, etc. If you have a welder easy to fix when it happens. Coating them will stop the rusting but the coating will cook off sooner or later as well.
If you were going with a single log I would try to sale you one, but your doing both.
Year worth of good boost you should be fine, just dont over heat the metal.
I would recommend supporting the turbos weight with some type of bracket to the block, head, something solid on the engine.
Old Oct 26, 2010 | 11:07 AM
What is my best option then, making tube headers?
Also, I'm not a GM.
Thanks.
Old Oct 29, 2010 | 12:07 PM
kbracing96's Avatar
.060 will crack over time MS or SS... best option is to use Sced 40 pipe and weldals. It's .375 thick and I've never had one crack.
GMCtrk
Oct 20, 2015 06:17 AM
gaps
Oct 15, 2015 02:53 PM
murderedSS
Sep 27, 2015 10:16 PM
Tuckin15s
Sep 23, 2015 09:35 PM
5.3lSilverado
Sep 20, 2015 06:48 PM
