Running a Turbo PCM and set up with no Turbo???
Old Sep 18, 2012 | 07:53 PM
TG02Z71's Avatar
Default Running a Turbo PCM and set up with no Turbo???
So I am going to be taking off my STS kit and going NA for a while. My engine has issues and I have to milk it until I have cash to build my boost engine.
Anyone see any issues with just going back to a CAI with the #44 injectors?
Old Sep 18, 2012 | 07:55 PM
Atomic's Avatar
I have a gauge for that
Keep the injectors and map sensor the same and it should be fine.
Old Sep 18, 2012 | 08:33 PM
03sierraslt's Avatar
Yep, agreed. I did this when I pulled off my Kenne Bell a couple years back for a bit and it ran fine. Actually I ran 2bar SD and I was NA for awhile. Ran fine, you are just not using as much of your VE table.
Old Sep 18, 2012 | 08:45 PM
silver-mod-o's Avatar
Hunt&Fisherator
I was fine doing this with a N/A 4.8 and 60# injectors.... I saw single digits for IDC from time to time lol...
Old Sep 18, 2012 | 08:57 PM
Ya I was NA with 72's, the injectors barely broke a sweat. Can't say the same now.
Old Sep 18, 2012 | 10:01 PM
Atomic's Avatar
I ran a 2bar sd with 60lbs on a stock 5.3 for a while, no problems.
Old Sep 18, 2012 | 10:07 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You'll be fine, just will never see about half of the VE and/or MAF tables.
Old Sep 18, 2012 | 10:12 PM
black00chev's Avatar
Slowest turbo build ever!
This is making me want to do my 60# injectors and 2bar MAP and get a good NA base tune before I get my turbo on. Since Ill be doing some trans work and getting a retune from Justin by the end of October.
Old Sep 18, 2012 | 10:41 PM
TG02Z71's Avatar
Good deal less BS to worry about
Old Sep 19, 2012 | 10:13 AM
nonnieselman's Avatar
I ran mine N/A when i took the STS off.. just took it off and didnt retune it.. it ran fine for several months.
It depends on how it was tuned also..
