Roush TVS Pullies
Old Dec 30, 2010 | 08:55 PM
  #121
TIM Z's Avatar
11 sec. Truck Mod
Looks great bud!
But you still have to press on the end right?
Thats a trick looking RIP pulley !
Now throw it on and have a sweet setup! That 4.8 is gonna be a stout little *** kicker!
Old Dec 31, 2010 | 10:45 AM
  #122
schino's Avatar
Originally Posted by TIM Z
Looks great bud!
the hub is still a press fit. its got a .001 press fit just like how the stock one was. it took me hanging on the handle of a 10 ton arbor press to get it on there so HOPEFULLY it doesnt go anywhere. its going to be a little bit yet before it gets on there because of all the supporting mods i gotta do and really no place to work on it at this time.
i think the 4.8 will be screaming for its life. does anyone know if someone has run a 2.8" pulley on a motor this small? my goals are to have a similar setup to bill but just a 4.8. if this survives a few months blower only its going to get a shot of nitrous on top
Old Dec 31, 2010 | 11:04 AM
  #123
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Turbogibbs back in the day ran a 3 or 3.1 pulley on his cammed 4.8 with a 112 and about 13#s of boost if I remember. He also broke three pistons later on because of detonation and running high timing.
Old Dec 31, 2010 | 11:50 AM
  #124
iamkeniff's Avatar
damn dude...that manifold looks amazing!
Old Jan 7, 2011 | 07:03 PM
  #125
aniversarysnake's Avatar
We have a similar set up for the roush tvs but its only a press on pulley and its a 2.7 made out of aluminum. Haven't bolted it on anything yet so I don't know any numbers yet. Let me know what you think opinions are welcome.
Old Jan 7, 2011 | 07:17 PM
  #126
Atomic's Avatar
I have a gauge for that
My math says a 2.8" pulley on a tvs1900 will make about 16lbs on a 4.8 with stock size crank pulley...
Old Jan 7, 2011 | 07:40 PM
  #127
6.055chevy's Avatar
I'd be scared that it will come off being made out of aluminum
The Neck looks really thin and may crack over time if you do a lot of High RPM pulls.
Also I'd like to see if the belts slips with 2.7.
Good Luck
You did do a good job it looks like.
Old Jan 7, 2011 | 09:49 PM
  #128
schino's Avatar
thats cool you went down the same road i did. looks good. what motor you going on with that 2.7 pulley?
i calculated that out to 16 also but was figuring on some losses from cam. i really dont want anymore then 15 because well.. 15 is prob too much as it is haha.
as far as cracks, my snout is still .3xx thick around the bearing, with the belt pulling down directly over that area i dont think it will cause any problems, im almost more worried about the area where it bolts to the head unit because it has a lot of leverage. if i can swing it id like to make a new tensioner, idler bracket which will have a leg going up to the bottom of the snout for more support. i also want to put a idler just to bottom left of the supercharger pulley so i get more then 180 degrees of wrap on the pulley.
on that note does anyone have a broken hd tensioner? i just want the spring out of it and to see how much tension its under
Old Jan 31, 2011 | 09:26 AM
  #129
guero68's Avatar
what the belt size that you all are using with the 2.8 pulley....
Old Feb 1, 2011 | 09:08 PM
  #130
schino's Avatar
mines not on the truck yet so cant tell you belt i use. i will most likely be using a tensioner and idler setup that ill make so it wouldnt help anyway
