roush intercooler pump problem
Old Jun 7, 2010 | 11:22 AM
t_thall's Avatar
Default roush intercooler pump problem
just finished installing a roush kit, wired in as per instructions. I was under the understanding that the intercooler pump runs whenever the engine does? or does it only cut in after something else is met? There is ground but no power to the pump.
Old Jun 7, 2010 | 11:34 AM
TIM Z's Avatar
11 sec. Truck Mod
Mine is wired to run with ignition on.
Its a bosch pump, same one other kits come with so shouldnt be a prob to get it going.
Its very quiet, you sure its not running? Take the resivior cap off and see if you can " see" any turbulence or flow in the resivior.
Old Jun 7, 2010 | 11:58 AM
Atomic's Avatar
I have a gauge for that
there definately needs to be 2 wires to the pump, power and ground
you can feel it vibrate slightly when its on.
Old Jun 7, 2010 | 12:20 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I'd recommend running it off it's own relay.
Old Jun 7, 2010 | 12:29 PM
t_thall's Avatar
It is on its own relay. I found the problem, my power point is one of the studs on the side of the fuse box and the fuse was on the wrong side, thanks though!
Old Jun 7, 2010 | 03:39 PM
TIM Z's Avatar
11 sec. Truck Mod
Cool, glad it was simple!
Old Jun 7, 2010 | 07:18 PM
smokeshow's Avatar
Mod with training wheels
The roush instructions actually specify that you put the pump's 12V power wire on a ground.....retarded.
Old Jun 7, 2010 | 08:54 PM
Atomic's Avatar
thats odd....that would make it spin the wrong direction...
Old Jun 7, 2010 | 11:56 PM
smokeshow's Avatar
No, it just makes it so both wires on the pump are tied to ground. lol
Old Jun 8, 2010 | 12:15 AM
Atomic's Avatar
then it doesnt work lol, no voltage drop = no current = no power
