rough idle after headers
Installed my headers on my joe gibbs supercharged. after which the engine light came on. it does have cats and a custom y pipe and all sensors are hooked up. (i double checked)ran fine for some time but now and again it idles real rough. if i get on it she whinenes up like normal. i put new plugs and wires. any ideas or has anyone had a similar problem?
I would think that if it was the plugs then it would have some power loss in the higher rpm range too but i could be wrong. found a guy thats gonna hook up a scanner to it monday. hopefully that brings up something that helps.
Your right i did brake a plug which i replaced before i posted the question! Checked the plugs for the FOURTH time as well as the wires. I did notice that the 4 plugs on the passenger side were BLACK (running rich) and the 4 on the driver side look normal. Looks like i have a fuel delivery problem. Mabey a bad fuel regulator?
still sounds like a bad plug or wire. if you have a missfire it will mess with the 02 sensor and cause the fueling to change. a missfire will usualy show lean and cause the computer to add fuel(black plugs).
there are lots of other things it could be but the most likely are the plugs, then the wires. make sure you use a proper spark plug socket and hold onto the head of the socket wrench when you tighten the last little bit, pull up a little as you push down on the handle. try and only put twisting presure on the plug, no presure on the side of it.
Hey looks like you guys were right! put new plugs in AGAIN and she runs good, so far anyways. either i screwed up or they sold me a bad one the other day. anyways your input is MUCH appreciated.
