rough idle after headers
Old Aug 4, 2007 | 02:59 PM
Blackice1's Avatar
Default rough idle after headers
Installed my headers on my joe gibbs supercharged. after which the engine light came on. it does have cats and a custom y pipe and all sensors are hooked up. (i double checked)ran fine for some time but now and again it idles real rough. if i get on it she whinenes up like normal. i put new plugs and wires. any ideas or has anyone had a similar problem?
Old Aug 4, 2007 | 04:18 PM
TURBHOE's Avatar
i would recheck the plugs alot of people have cracked them and not been able to tell and it will cause it to idle ruff. check eng lights are your friend what is the code.
Old Aug 4, 2007 | 05:00 PM
parish8's Avatar
single digit dreamer
i 2nd the plugs. might as well just swap them out to be sure and double check you plug wires. make sure they are clicked on and not burnt anywhere.
Old Aug 4, 2007 | 05:57 PM
Blackice1's Avatar
I would think that if it was the plugs then it would have some power loss in the higher rpm range too but i could be wrong. found a guy thats gonna hook up a scanner to it monday. hopefully that brings up something that helps.
Old Aug 4, 2007 | 09:19 PM
BlownChevy's Avatar
blownerator
25 Year Member
9 times out of 10 you broke a plug or damaged a wire....just like the others have told you. Not need to hook up a scanner, its going to tell you where the misfire is, and you will still need to check the plugs and wires. Headers do not cause a rough idle.
Old Aug 5, 2007 | 12:53 AM
Blackice1's Avatar
Your right i did brake a plug which i replaced before i posted the question! Checked the plugs for the FOURTH time as well as the wires. I did notice that the 4 plugs on the passenger side were BLACK (running rich) and the 4 on the driver side look normal. Looks like i have a fuel delivery problem. Mabey a bad fuel regulator?
Old Aug 5, 2007 | 01:42 AM
parish8's Avatar
still sounds like a bad plug or wire. if you have a missfire it will mess with the 02 sensor and cause the fueling to change. a missfire will usualy show lean and cause the computer to add fuel(black plugs).
there are lots of other things it could be but the most likely are the plugs, then the wires. make sure you use a proper spark plug socket and hold onto the head of the socket wrench when you tighten the last little bit, pull up a little as you push down on the handle. try and only put twisting presure on the plug, no presure on the side of it.
Old Aug 5, 2007 | 11:26 AM
Blackice1's Avatar
K sounds good. better do that before buying some pricy electronics. Thanks for your help all!
Old Aug 5, 2007 | 04:46 PM
BlownChevy's Avatar
blownerator
25 Year Member
if the truck ran fine before the headers, then it should run just fine with them. If it does not, you need to check things in the area of the install.
Old Aug 6, 2007 | 07:30 PM
Blackice1's Avatar
Hey looks like you guys were right! put new plugs in AGAIN and she runs good, so far anyways. either i screwed up or they sold me a bad one the other day. anyways your input is MUCH appreciated.
