Reg Cab 03 Trick Turbo Build--Pics Inside!
Old Apr 19, 2015 | 08:45 PM
Dusty05's Avatar
Default Reg Cab 03 Trick Turbo Build--Pics Inside!
Decided to share a few pics of my 03 build. Still coming together but making progress. As soon as i get some time, I'll be doing head studs, ls9 gaskets, ls7 lifters, cam swap, and more boost.
Old Apr 19, 2015 | 08:55 PM
GMCtrk's Avatar
Looks good.
Those trans lines scare me though.
Old Apr 19, 2015 | 08:59 PM
Dusty05's Avatar
Thanks!
I need to grab a new pic...I have braided line now from the trans to the trucool.
Old Apr 19, 2015 | 09:28 PM
mdwatts11's Avatar
Looking great. I may have missed it but how many pounds of boost you running? Also, I would recommend doing LS9 head gaskets. LS3 won't really buy you much.
Old Apr 19, 2015 | 09:31 PM
Dusty05's Avatar
I'm currently running 8 psi...i meant to put ls9 gaskets...long day lol
Old Apr 19, 2015 | 10:14 PM
RS/SS 4.8's Avatar
10 Second Truck Club
Looks good. Is that pushloc hose on that drain fitting? If so youre not supposed to use hoseclamps on it. It will actually cause the barbed part of the fitting to cut through the hose n cause a big ole mess.
Old Apr 21, 2015 | 10:41 AM
LQ4JOSE's Avatar
do you have any pics of how you mounted the tru cool?
Old Apr 21, 2015 | 11:35 AM
Dusty05's Avatar
I can take some later today. I took the AC out of my truck since it's a weekend / strip only truck. I mounted the Tru Cool behind the A-frame where the condenser was.
Old Apr 28, 2015 | 11:43 PM
AlwaysOnKill's Avatar
Looks good ! How much power did it dyno?
Old Apr 29, 2015 | 09:52 AM
Mike1992's Avatar
Looks good Have anymore engine bay pics? How did you run the intercooler? Turbo setup specs?
