Ran truck for first time at track.. Disapointed!
Old Oct 27, 2012 | 08:05 PM
  #21
patofdzb's Avatar
Thanks Guys, im quite satisfied with Justin... its my truck who im disapointed in
I would LOVE to learn how to tune and do my own truck, but i dont know a rats *** about tuning.. ive tried reading some, but i wouldnt know where to start... MAYBE if the tunes werent locked i could play around some, but theyre locked so i would hace to start from zero.
I AM MAF tuned, asked justin if we should switch to SD, and he said its not necessary..
I know that my TB converter is a POS and i will never launch good till i put a good one in.. (Saving up for 80e & stall)
But i just dont get it why i´ve done better times with a 125 shot of nitrous.. than with 12 psi of boost...
I did forget to mention i have LS6 cam & springs installed
nonnieselman,
i dont have a FP gauge, but im pretty sure fuel pressure is above 60 :s
& thanks alot, i really apreciate you giving some time to read my log
Old Oct 27, 2012 | 09:21 PM
  #22
lglowe's Avatar
Your tune shouldn't be locked. You just cant veiw the tune using your autocal. Been there and done that with Justin and it was a waste mail tuning a turbo imo. Buying v2 was the best money I ever spent and its really not that hard learning. I'm sure there are a lot of experienceed tuners on here that could help you make changes as well... Just gotta buy the software...
Old Oct 27, 2012 | 09:50 PM
  #23
patofdzb's Avatar
so im guessing it would be buying a FlashScan V2 ? can i buy it without licences?
So would you guys reccomend EFI´s FlashScan V2? or buying an HP Tuners?
Old Oct 27, 2012 | 10:27 PM
  #24
lglowe's Avatar
Get efi live v2 since your tune is already made up with efi live. If you got HP tuners you'd have to start over I think
Old Oct 27, 2012 | 11:01 PM
  #25
Suburbazine's Avatar
I didn't see you mention an intercooler anywhere. I'm supposing you do have one, right?
Old Oct 28, 2012 | 04:53 AM
  #26
patofdzb's Avatar
yes sir, of course i have one.. Here are more specs on the truck:
-On3Performance T76 Turbo T4 .96a/r Journal Bearing
-Trick turbo Hot Side all wrapped in DEI titanum
-Ebay Intercooler Kit 31*12*3
-50mm Wastegate with dump tube
-FAST 57lb/hr injectors on Stock Rail (RETURNLESS)
-Stock pump (non flexfuel) and Walbro 255 on hobbs switch at 4psi (Both in Bucket)
-02 LS6 cam & yellow LS6 springs
-True Trac w / stock 3.73 gears
-stock 4L60e with HD2 shift kit, corvette servo, & 40k Tru Cool Transcooler
-Reman. stock TrailBlazer I6 Stall
-TR6 plugs gapped at .026 (stock wires with DEI Sleeves)
-MSD LS 2-Step, Innovate Wideband
thats about it
Old Oct 28, 2012 | 09:06 AM
  #27
RibeiroBJJ's Avatar
Praise The Lowered
I am sure if you can get a few guys together Justin would come down for a Tune session...We practically live in Mexico...
Old Oct 28, 2012 | 09:48 AM
  #28
Beatdown Z's Avatar
Laid Back
Don't worry about how slow it is right now. It can all be fixed in the tune.
My truck is setup similar to yours, but with a 5.3 and 212 cam. Ran 12.4 at 115 on 11psi with a terrible 2.2 second 60' time.
I'd also suggest you put in some non-projected tip plugs, like NGK BR6EF or BR7EF's, to help deter detonation.
Old Oct 28, 2012 | 10:09 AM
  #29
foose04's Avatar
Without knowing the MPH or 60, it's hard to say where it's lacking the most. The sputtering is usually plugs and the timing could us a slight bump up, but again more info is needed to say where the real issue is.
Old Oct 28, 2012 | 10:31 AM
  #30
TRD_Tundra's Avatar
And I thought mines ran horrible.
But mines an Ext cab 5.3 with an identical set up, except I have a stock 4l80e stall and stock G80 3.23's on street tires.
Mines also at 12psi but on meth w/ 14* timing.
I ran 13.7 @109.6 W/ 2.5-2.6 60ft and it doesn't break loose of the line. Shows how horrible my digs are.
