radix why is it lean.
Old Mar 14, 2007 | 03:06 AM
  #21
sirk's Avatar
well i got brand new 44lbs in there right now. ( the ones that came in the accessory box ). im gonna check tomorrow for a vacuum leak when i get back home. ive been gone for a bit now and havent seen my truck. i hope i figure it out and the shop just fixes it with no hassels.
Old Mar 31, 2007 | 06:31 AM
  #22
sirk's Avatar
could a loose evap solenoid be the cause of my vacuum leak? ive been tryin to find it but only came across a loose evap solenoid. i can push it side to side exposing a good quarter inch or so gap between it and the manifold. also the two screws on the top of the supercharger intake about 3 inches behind the throttle body were very loose ( only screwed about half way in. i could move them no prob with fingers ). i tightened these up too. since that no light has come on but i dont know if enough air could pass through that hole with the screw in it to cause problems. im gonna check the fuel trims in few days when im home with the truck.
Old Nov 29, 2007 | 10:02 PM
  #23
gonzo 6.2's Avatar
I see in another post you must have figured out your lean problem,I looked at your past posts and didnt see what the fix was.What was it?
Old Nov 30, 2007 | 02:42 AM
  #24
sirk's Avatar
stupid tuning problem with 06 vmax's. i had to zero out the whole table on PE mode and just go by throttle position ( TPS ). its all good now tho. need a good cam and meth to hit 500whp.
bagged7104SS
Sep 24, 2015 08:42 PM
Lamartian92
Sep 10, 2015 09:27 PM
Lamartian92
Aug 21, 2015 01:43 PM
therock
Jul 25, 2015 09:23 AM
sTNT971
Jul 16, 2015 12:39 PM
