radix why is it lean.
i cant here any knocking or pinging. but im taking it easy. havent really driven it much latetly. what are the best places to check for a vacuum leak? right at the manifold? maybe a bad gasket? also fuel pressure is good.
Performance Trucks Sponsor
good luck,
allen
still havent figured it out. ive been away from my truck for a few weeks. ill be checking it out on wednesday. i called the shop that did the install and they said to check for a vacuum leak if i can then bring it in. when checking for a vacuum leak do it yourself style, whats the best way? carb cleaner? where all should i look? just around the manifold or anywhere else? thanks alot.
Ether spray. Anywhere after the MAF that air could be getting in. The manifold to heads is a likely suspect. Could have cut the gaskets during install. Only do a few minutes at a time then let the truck cool. Maybe its just me but I don't like spraying flammable things on a hot engine.
