radix why is it lean.
Old Feb 19, 2007 | 05:39 PM
Slowhawk's Avatar
LS1Tech Sponsor
Too lean would be a tuning issue,low fuel pressure or a vacuum line disconnected.
It needs to be scanned.
Old Feb 19, 2007 | 07:19 PM
FarmTruc's Avatar
Performance Trucks Sponsor
Your ltrims are probably +25, if so, you have a vacuum leak.
good luck,
allen
Old Feb 20, 2007 | 08:55 AM
sirk's Avatar
i cant here any knocking or pinging. but im taking it easy. havent really driven it much latetly. what are the best places to check for a vacuum leak? right at the manifold? maybe a bad gasket? also fuel pressure is good.
zippy's Avatar
I would agree that you either have a vacuum leak or a problem at the fuel pressure regulator (which is in the tank). I would assume your problem came about when the fuel pump was installed.
Old Feb 20, 2007 | 09:29 AM
FarmTruc's Avatar
Try finding a shop that has a smoke machine, they'll pump smoke into the engine and where ever the smoke comes out...
good luck,
allen
Old Feb 20, 2007 | 09:53 AM
BlownChevy's Avatar
blownerator
25 Year Member
depending on who did the install, it is more than likely an install issue. I would start checking your install and backtrack through everything.
Old Mar 5, 2007 | 07:51 PM
gonzo 6.2's Avatar
Did you figure it out?
Old Mar 10, 2007 | 02:43 PM
sirk's Avatar
still havent figured it out. ive been away from my truck for a few weeks. ill be checking it out on wednesday. i called the shop that did the install and they said to check for a vacuum leak if i can then bring it in. when checking for a vacuum leak do it yourself style, whats the best way? carb cleaner? where all should i look? just around the manifold or anywhere else? thanks alot.
Old Mar 10, 2007 | 02:46 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Ether spray. Anywhere after the MAF that air could be getting in. The manifold to heads is a likely suspect. Could have cut the gaskets during install. Only do a few minutes at a time then let the truck cool. Maybe its just me but I don't like spraying flammable things on a hot engine.
Old Mar 12, 2007 | 10:38 PM
whitewhale01's Avatar
I had a similiar issue. It turned out to be a combo of bad fpr gasket and stock plugs were way to hot. I believe they were replaced with ngk tr6 I think. I can check if you want.
