Radix troubleshooting
Old Dec 11, 2005 | 11:12 PM
SnakePilot's Avatar
Angry Radix troubleshooting
I intalled the radix with a Nelson tune and the engine tries to start but won't continue to run.
Any ideas? Anyone know of a shop in Vegas that can take a look at it for me? I need it repaired ASAP.
Old Dec 11, 2005 | 11:16 PM
moregrip's Avatar
what a rush!
install the tune that came loaded on the superchips tuner
Old Dec 11, 2005 | 11:19 PM
BlownChevy's Avatar
blownerator
25 Year Member
how about some info....
year of truck is a good place to start.
Old Dec 11, 2005 | 11:28 PM
BlownChevy's Avatar
blownerator
25 Year Member
Just got it....
sounds to me like you have a bad case of VATS......
Not a Radix problem, more like a tunning issue..put your orig PCM in and program it with the superchips tuner.
Old Dec 12, 2005 | 09:29 AM
SnakePilot's Avatar
Sorry, the truck is a 2002 Avalanche with a 5.3. I'll try the orginal PCM tonight when I get home. Any other things to try if that doesn't work?
I thought the install was very straight forward with very good directions.
Thanks for the help,
Tim
Old Dec 12, 2005 | 09:34 AM
BlownChevy's Avatar
blownerator
25 Year Member
Tim
If you are saying that it is fireing then shutting down right after it is more than likely the VATS. You can use your Original PCM if you have the superchips programer to flash it with.
Fogle07's Avatar
when you install the tune that comes with the radix im sure it will work just fine. i think you should always install it the way it comes before you change anything in case there are any bugs. good luck with it
also it could need an idle relearn. when you crank it see if you can keep it running by giving it a little throttle if you can then it needs the idle relearn. if you cant keep it running then put the stock tune in it. to do the idle relearn crank the truck up and hold your revs to around 1000 for like 30 seconds.
Old Dec 12, 2005 | 10:28 AM
Steve Bryant's Avatar
LS1 Tech Veteran
Brian,
What is VATS?
Thanks,
Steve
Old Dec 12, 2005 | 10:33 AM
Fogle07's Avatar
Originally Posted by Steve Bryant
Brian,
What is VATS?
Thanks,
Steve
vats is an antitheft feature. there is a ring around your key cylinder and i believe a chip in the key and it senses it and lets you crank the truck up. go to the dealer and get them to cut you just a door key and it will only crank the truck up and it will shut right back off because its not programmed to the truck.
Old Dec 12, 2005 | 10:35 AM
BlownChevy's Avatar
blownerator
25 Year Member
Brian,
What is VATS?
Thanks,
Steve
It is a really bad rash that requires a special cream........Oh wait....
V ehicle
A nti
T heft
S ystem
