Radix owners and tuners???
Old Jan 18, 2007 | 12:51 PM
Default Radix owners and tuners???
what are ya'll running for boost and what a/f ratio are ya'll at, and what motor. i wanna make sure mine is safe when i get it retuned. screw tryin to get it to make a crapload of hp, i just want it to make descent power and hold up!
Old Jan 18, 2007 | 01:10 PM
Last Call's Avatar
TOTM: January 2007
Im running about 8.5 psi with a 2.9 pulley on an LQ4 6.0 with true duals. My AFR is 11.8.
I think you should be running more like a 3.0-3.1 pulley if the engine is a 5.3. Not sure how you are going to make decent power without the pcm pulling significant timing from very high IAT's.
I say run less boost and more timing...
Old Jan 18, 2007 | 01:18 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
9lbs. peak boost with 3.2" pulley. A/F is ~11.6
Going to dyno today and work on the mix a little more.
I agree with J too.
Old Jan 18, 2007 | 01:35 PM
BlownChevy's Avatar
blownerator
25 Year Member
Then take that 2.9 off and install a 3.2, get it tuned and get on with your life.
Old Jan 18, 2007 | 01:57 PM
KySilverado's Avatar
About 9psi. I shoot for 11.8 AFR with methanol and about 11.6 without.
Old Jan 18, 2007 | 02:09 PM
04Denali's Avatar
Im running about 7.5 psi with a 3.0 pulley on an LQ4 6.0 with true duals. My AFR is 11.5 through fist and second gear and than 10.5 in third.
Mark
Old Jan 18, 2007 | 04:15 PM
ive got the 2.7 on now. i think ill go with the 2.9 and shoot for 11.5 a/f ratio across the board. that should be safe huh? i think it pulles about 9lbs or so with the 2.9.
Old Jan 18, 2007 | 04:18 PM
GMC_DUDE's Avatar
3.25" pulley, about 10 psi max., and AFR around 11.0. So far so good.
Old Jan 18, 2007 | 04:30 PM
dhpro's Avatar
Fresh install was 6.5lbs and 11.8 AFR...custom tune was 12.2 AFR...gave me a little more power in humid conditions, and burns like a champ in cold weather!
Old Jan 18, 2007 | 04:54 PM
Last Call's Avatar
TOTM: January 2007
Something is not right if you are making just 9psi with a 2.9 pulley on a 5.3. I hit 9psi with a 3.1 pulley on a 5.3.
