Radix + Nitrous..outcome?
Old Jul 22, 2009 | 05:37 PM
cccharged's Avatar
Originally Posted by skyhighsami
Nah, ZEX I think makes a kit on the end where on a cone filter it says KN that they put a nozzle. They spray across the MAF and let it richen the intake. Again, only if you have enough injector to support X amount of boost and the adding N2O
Yes, exactly. It is a ZEX kit. My tuner had a T/A that he had this kit on and he sprayed it into the filter as it is stated above and he said it worked really well for him...i was just questioning ab it..kinda stumped on it
Old Jul 22, 2009 | 05:42 PM
skyhighsami's Avatar
no title here
I think I read someone or had some friend's here locally that ran ZEX and said it wasn't very good and changed the nitrous to a Nitro Dave's kit and picked up a good bit. I think the problem was the soleniods or the MSD looking box that it flows through to "verify enough vacuum to activate n2o)
Old Jul 22, 2009 | 05:54 PM
cccharged's Avatar
I have never had anything with nitrous on it..i have seen it used of course but dnt know much ab it as you guys can tell...i do know the diff in dry and wet..and that dry is nitrous only and wet is nitrous+fuel...But i have done some reasearch on it ab how it is suppose to drop the intake charge temp....? Is this a no or yes? Or maybe on a N/A engine vs a charged engine?
Old Jul 22, 2009 | 06:04 PM
Atomic's Avatar
I have a gauge for that
The cooling effect comes from the extra injected fuel, not the nitrous. The nitrous adds more oxygen = more power. If you inject nitrous without extra fuel you will run very lean and burn stuff up. The reason you never see big dry shots is the stock injectors cannot put in enough fuel to be safe.
If you are just looking for cooler temps methanol is a better alternative. Both can be used in conjuction as well, as I think trever is doing. Heck with a diesel you can inject nitrous, meth, fuel, and propane at once!
Old Jul 22, 2009 | 06:05 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I have run 35/50/and 75 shots thru my Radix with no noticible drop in IAT's. I have not heard of any of the other users on these boards ever report any IAT differences but you will make gobs more power without increasing IAT's if that counts. Spraying methanol didn't really drop IAT's all that much eaither
Old Jul 22, 2009 | 06:16 PM
cccharged's Avatar
Ha..so basically there is no way to drp IAT's then?..i only want to do a small shot(35)..what kinda diff would thins make in power and torque?
Old Jul 22, 2009 | 06:27 PM
trever1t's Avatar
35-50 increase in hp/tq
Old Jul 22, 2009 | 06:29 PM
trever1t's Avatar
4.8L with Radix...what pulley size, how many kPa or lbs. you making? What's your intake setup? Exhaust?
Old Jul 22, 2009 | 06:34 PM
cccharged's Avatar
3.2 pulley at ab 9#s..Volant CAI..hooker shorty's no cats..factory Y pipe..3" midpipe into 3''center in center single Magnaflow
Old Jul 22, 2009 | 07:04 PM
cccharged's Avatar
? good or bad?
